RE: Need help on how to cover my Sig Cub
Gene,
If you are covering over open bays the easiest way is to first lay down your base color and then apply your striping color over the top of that. If you are using Monokote I would suggest using the Windex method for the stripes as it will eliminate bubbles in the covering.
Ken
