RE: Need help on how to cover my Sig Cub
the windex method will not work with ultracote. It has a differnt adhesive than monokote. But the method is: put your base coat down, tighten with the heat gun then spray a small amount of windex (original formula) and spead it around with a damp paper towel. Lay the trim color down and use a old credit card or something on that order and work out the bubbles. Let dry overnight or longer.
