RCU Forums - View Single Post - Need help on how to cover my Sig Cub
Old 02-27-2009 | 10:36 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Need help on how to cover my Sig Cub
ORIGINAL: goirish
Hummm!!! looking at the picture of the fuselage again, I wonder if I could put the color down first then use the windex method for the white. There is more color than white on the sides.
Gene,
You want to avoid putting a light color over a dark color because the darker color will show through the lighter color. So put your darker stripes over the white.
I will be using ultracote can I put ultracote over ultracote and what is the windex method?
Yes, you can use Ultracoat over Ultracoat. The Windex method is a way of applying Monokote over another covering using Windex. You basically spray Windex on the surface, place your Monokote on the area, slide it in position, squeegee the Windex out, and then let it dry. This is a great method for applying Monokote as it does it without any bubbles forming in the Monokote. It works only for applying Monokote because the ammonia in the Windex activates the adhesives in the Monokote to adhere it to the covering below. Here is a more detailed description of how to use this method.
[link=http://www.rcuniverse.com/forum/m_603331/anchors_603331/mpage_1/key_flag/anchor/tm.htm#603331] Applying monokote with Windex. [/link]
Ken
