RCU Forums - View Single Post - Installing Servos
Old 02-27-2009 | 01:11 PM
Bob Mitchell
Default RE: Installing Servos
ORIGINAL: bruce88123
I have not yet seen a Futaba servo with 2 grommets. When did this start and on which servos?
I've used Futaba 3004's, 3152's and 3010's The higher torque 3152 and 3010's came with came with 4 rubber grommets that push fit at each of the four mounting lugs. The lower torque 3004's also came with 4 grommets. Each had 2 holes side by side, with one fitting on top of the servo and the other underneath, two at each "end" of the servo. They are a PITA since neither will stay in place until you get the eyelets pushed through.
