RCU Forums - View Single Post - Comp ARF Flash update
Old 02-27-2009 | 01:44 PM
  #774
KC36330
Default RE: Comp ARF Flash update
ORIGINAL: raptorlogo
Hi KC36330,
I will soon finish my Flash powered by a Wren 160.
Like you, I will only use the upper part of the bypass.
Do you have any ballast in the nose ? How much weight ?
Alain
i do not have any additional weight added BUT with the Titan SE installed i used a powerbox that i had and wasn't using so i've got 2 Li-Ion batts for the receiver, i did have to put the Li-Mg ECU battery in the nose next to the air tank, that gave me a balance of 367mm.
i also have my fuel pump in the forward left side of what was intended as the battery compartment next to the nose wheel just in front of the ECU
