RCU Forums - View Single Post - Absolute genious.
Old 02-27-2009 | 01:57 PM
-pkh-'s Avatar
-pkh-
Default RE: Absolute genious.
You must have a 3-wire charge port, and unless you buy the JR or Spektrum wire harness, it is probably not 3-wire. The bind plug shorts the signal and ground pins on the batt/bind input to the receiver. Most wiring harnesses only have the power and ground wires going to the receiver for power, they omit the signal wire.
