I would like some help.....I am ordering an aeromarine 56" apache with twin rails. I Have 2 zen whh with clutches and xp-2 drive lines. I am going to rotate one jug and piston to have both carbs in and both exhausts out. I have tuned wet exhausts for them also.
Do I have the cables exit the transom on this boat or is it better to come out the bottom. Is the cg as usual for twins as singles....approx 25-30% of length.
I also have an order for a couple of zen twins for an 84" apache....same as twin singles, rotating one twins jugs and pistons. Going with a mild mod and using straight pipes and water injection.....I'm pretty sure these drive lines come out the transom. Is the balance point the same 25-30% of length.
Both builds will not be counter rotating, is this ok, or a waste of time.
Any help would be
[email protected]
