ORIGINAL: combatpilot
I am just guessing but I think the weight savings to be arouind 1 lbs I will keep track of it when i do the conversion. I ordered my ignition a couple of days ago.
Well 1lb would be a substantial weight savings using EI. I also considered maybe converting over to glow/gas which would also save some weight. I am getting ready to test this engine with an 18x8 APC. This is a stock single ring Ryobi 31 with no modifications. I will tach it when I do the test run and post my numbers using Lawnboy mix 32:1.
