RE: Leaking muffler problem
Where does it leak at? I've sometimes used a little RTV on the flange where it meets the cylinder. I've also done it to the joint where the two muffler sections fit together. Another option on that joint is to just TIG weld it. Only down side is you can't move the exhaust outlet any more.
