RCU Forums - View Single Post - Edge 540 fin angle is off
Old 03-02-2009 | 03:15 AM
Ernie Misner's Avatar
Ernie Misner
Default RE: Edge 540 fin angle is off
The angle was off quite a bit, maybe 15 degrees or so. The fin was not made properly. I had to make a wedge that tapered from about 3/32" to fill in that gap. The only other option was not to keep the rudder hinge line straight in it's groove but that would have been a bad idea as you noted.
Of interest is that the directions on the CD are showing pictures and giving info on assembling the Fusion, not the Edge. (like checking for clearance on the counterbalances on the elevator (aren't any on the Edge) and reaching through the hatch on the left wing (it's on the right wing on the Edge) to tighten the wing bolt), etc. That isn't a big deal to me at all but I had to chuckle since I have a Fusion sitting right here too.
Thanks for being here for us,
Ernie
