RE: Hi-Tec RX Mini 6
Hey Gene,
It will work with the Futaba. I have used this setup before and it does work.
I would caution you that I would not put it into a glow plane. I tried this and I had numerous glitches with mine at range. They claim it is full range, but I was able to bring it back to the LHS that I bought it from and exchange it for a Supreme IIs. I would recommend the Supreme, it is a bit more, but it is 8ch and dual conversion.
The difference between the single and dual exists only in the Rx and it relates to the Rx converting the signal from the 72 Mhz down to the frequency where the Rx decodes the info. It is a common conception that dual conversion is better for larger applications that need the range, but I believe that Berg's 4 and 7 ch Rx's are both single and they are well received.
Just my personal experience with them.
Best Regards,
Curtis
