RCU Forums - View Single Post - Balancing the PT-40
Old 03-02-2009 | 03:43 PM
Bax
Default RE: Balancing the PT-40
ORIGINAL: jmwright75
Ok so im at the point in the instructions to balance my plane. It says that on the PT-40 the balance point is 4 7/64" from the leading edge. I have the GP balancer. And have set it so the points are as close to the fuselage as i can get them. I have the battery moved back as far as possible as with the servo tray, and I am coming up very nose heavy. Has anyone balanced one of these and know if that is the correct point. I thought i read somewhere on a thread that that wasn't accurate for the cg. The 4 7/64" puts it right behind the main spar. If it makes a difference the engine im using is the OS 46 LA. Any insight on this would be great. Thanks.
john
Balance is not that critical. If you're very close, you'll be OK.
