RCU Forums - View Single Post - My 70mm spinner split on the first throttle up...
Old 03-03-2009 | 12:57 AM
opjose's Avatar
opjose
Default RE: My 70mm spinner split on the first throttle up...
You may have burned the motor out.
If you can remove the fan, make sure that all three connectors are hooked up, and power on the TX.
Then with the throttle down, turn on the plane.
Do you hear the beeps coming from the plane?
If you do not then it could be that the throttle lead is disconnected, or that one of the motor power leads is off.
If you do hear the beeps, throttle it up slowly.
Does the fan begin to turn?
If not you may have a burned out wire in the motor, cause by the restriction of the fan.
