RCU Forums - View Single Post - Skygate Hawk Maiden Flight
Old 03-03-2009 | 05:12 AM
darryltarr's Avatar
darryltarr
Default RE: Skygate Hawk Maiden Flight
Both Ailerons raised:
This reduces the Angle of Attack of the wing tips, a bit like having washout, the center of pressure would move forward slightly and you could end up with a pitch sensitive model (dont relate this to "CROW" as a crow set-up is for landing when you have a model that has a huge flaps surface area and large deflecations).
Set the triling edge of the ailerons in-line with the trailing edge of the flaps (make sure the flaps are fully retracted, as far as they can go mechanically.
