RCU Forums - View Single Post - Ugly Stick Build
Old 03-03-2009 | 01:37 PM
  #41
Nergall
Default RE: Ugly Stick Build
I installed the wing bolt blocks here.
The eccentric shape of the plywood below is because I used some leftover plywood pop outs from a 4*60 fuse side. However, it does what I want - which is to connect the forces on those hardwood blocks to the F4 bulkhead, a larger area of the 1/4 balsa sides, and to the base of the fuselage.
