RCU Forums - View Single Post - balancing
Thread: balancing
Old 03-03-2009 | 09:38 PM
flynte
Default RE: balancing
In my opinion, if you go to the center of the recommended range for cg and be slightly nose heavy then that should be a safe place to start your test flights from there. This is usually where I start with mine for the first flights and then tweek from there.
flynte
