RCU Forums - View Single Post - Good Dremel for cutting cowls?
Old 03-04-2009 | 09:47 AM
Airbus 9e
Default RE: Good Dremel for cutting cowls?
ORIGINAL: fxstb
I have a fiberglass cowl that i need to cut to fit the muffler, what would be the dremmel attachment that i should use? Also, what is the best way to do it?
I would say to rough cut it with a cutoff wheel, then smooth it out with the sanding drum.....
