ORIGINAL: ImHooked
ORIGINAL: fxstb
I have a fiberglass cowl that i need to cut to fit the muffler, what would be the dremmel attachment that i should use? Also, what is the best way to do it?
I don't know what you call the attachment, but it is the one that looks like a drill bit just not wound as tight,,,,if that makes sense. I used card stock to make a template, traced it on the cowl and then carefully went around the trace that I made with that funny looking drill bit attachment (and used a pretty high rpm on the dremel) and viola, I had a cutout in my cowl. It needed very little clean up with the sanding drum. BE CAREFUL with the sanding drum,,,,it doesn't need very much pressure at all.
Good Luck,,,,,you just get one shot at it!!! It's really not that hard!!
Double what he said on the sanding drum, especially on high speed. It will eat through a glass cowl like a hot knife through butter![X(]
