RCU Forums - View Single Post - Good Dremel for cutting cowls?
Old 03-04-2009 | 10:20 AM
Gray Beard
My Feedback: (-1)
Default RE: Good Dremel for cutting cowls?
Fiber glass does not like to be cut, it tends to fray, use the sanding drum. On big areas I use a cut off wheel then the drum. The sanding drums come in a couple of different sizes. They are not that hard to work with if you use the speed control.
