RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 03-04-2009 | 11:25 AM
  #3933
playntraffic's Avatar
playntraffic
Default RE: DL-50 engine
Yes the wings are on. The needles are at the factory setting and the low end seems pretty rich. There is some smoke at the 2500rpm. I am going to try and set the low end for a good transition and see if that helps. I have not opened it up to WOT to set the high speed needle, it is still at the factory recommended setting. I am also still using the cheapo stock plug. Figure I will put the CM-6 on it after the break-in.
I am doing the break-in according to the manual. Probably being too conservative.
http://www.youtube.com/watch?v=sbc-MlekL-k
