RE: Good Dremel for cutting cowls?
For rough cutting large areas quickly, nothing beats the suggestion given here, to use a drywall side cutting bit with your Dremel tool.
Drill a hole to start, then use the side cutting bit to rough out the area.
Finish off with a sanding drum as suggested.
Apply thin CA to the edges of the cut out areas to harden and prevent cracking.
