RE: Blade 400 binding problem
with all toggle switch`s in the (0) possition
place bind plug in port one of the reciever.then plug in heli.
while holding the trainner switch in the up possition turn on the radio/tx.
you`ll see the word bind in the viewing screen
after light on reciever stops blinking rotate both sticks in all direction`s while still holding the trainner switch
after your done turn off radio and unplug heli and remove binding plug
then turn radio back on and then plug heli in
should be good to go
