Blade 400 binding problem
My blade 400 will only bind with the throtle hold switch on, and then it ramps up to full speed. It will not bind in the mix or normal switch position.[&o] Any help will be appreciated. I down loaded the factory settings and think I have it set up right...
MI
with all toggle switch`s in the (0) possition
place bind plug in port one of the reciever.then plug in heli.
while holding the trainner switch in the up possition turn on the radio/tx.
you`ll see the word bind in the viewing screen
after light on reciever stops blinking rotate both sticks in all direction`s while still holding the trainner switch
after your done turn off radio and unplug heli and remove binding plug
then turn radio back on and then plug heli in
should be good to go
MI
ORIGINAL: rcbartra
Just curious:
What does rotating the sticks do? I never had that problem, but it's always good to know.
thanks
Just curious:
thanks
and it helps you see that everything is working properly
