ORIGINAL: opjose
You may have burned the motor out.
If you can remove the fan, make sure that all three connectors are hooked up, and power on the TX.
Then with the throttle down, turn on the plane.
Do you hear the beeps coming from the plane?
If you do not then it could be that the throttle lead is disconnected, or that one of the motor power leads is off.
If you do hear the beeps, throttle it up slowly.
Does the fan begin to turn?
If not you may have a burned out wire in the motor, cause by the restriction of the fan.
ok, i have check all of the above, the motor turns, but no beeps when i plug in the battery, even with a full charge. all power leads are connected. throttle lead is connected. everything else works fine but the motor. seems theres no response to any throttle input from the controller.
