RCU Forums - View Single Post - My 70mm spinner split on the first throttle up...
Old 03-05-2009 | 08:29 PM
  #35
dieter1999
Default RE: My 70mm spinner split on the first throttle up...
ORIGINAL: opjose
Ok, this still suggests the ESC, so what about continuity accross all three leads.
In other words no matter which two you test, you should get continuity.
Try the three combinations and report back if you would.
ok, i tested all three leads and got zero resistance. Im suspecting its the esc
