RCU Forums - View Single Post - My 70mm spinner split on the first throttle up...
Old 03-05-2009 | 08:34 PM
  #37
opjose's Avatar
opjose
Default RE: My 70mm spinner split on the first throttle up...
ORIGINAL: ftherrmann
Nope.. I looked at it again... Here's a cut and paste...
❏ 4B. If you are installing the optional rotor cone, press it
onto the fan rotor as shown.
Then they talk about cutting away a portion of the aft cone for cooling....
Do you have one of these?
I have several... I can GUARANTEE you that it is NOT optional.
The blunt front of the assembly degrades air flow by over 50%! if the cone is not installed.
