RE: Is The High Flow Fuel Line Worth It?
Very true about the pipe in there so that the line doesn't get pinched down. As for "high flow line" - If you can tune your carb to run the engine plenty rich through the range of throttle then you are already getting all the fuel flow that you could ever need. "high flow" sounds like a nice marketing theme to make people think that it would offer their model better performance to increase sales of the product. However, if it is quite affordable and you get the rigid tubing that you need then why not?
Does it also come with line and a clunk filter for inside the tank as well? That would make it good for models that don't come from the factory with that type of set-up. [8D]
