RCU Forums - View Single Post - Calibrating ECU temperature
Old 03-06-2009 | 06:28 AM
George
My Feedback: (57)
Default RE: Calibrating ECU temperature
Tor, it's parameter #47 under the Autostart Menu:
To enter the 4:AUTOSTART menu, first press the SET key and then use the Up/Down keys to switch between the available parameters.... 47: EGT/AMBIENT
Use this parameter to adapt the temperature sensor (EGT zero point) to the current ambient temperature
Standard value: e.g. 21 °C (70 °F)
After a re-installation, this setting should be checked and corrected if necessary!
To change a setting, first press the SET key and then use the Up/Down keys to switch between the available values. A ? indicates the value to be set. To finish the setting and store the new value, press the SET key again.
