 Calibrating ECU temperature >
Old 03-06-2009 | 04:23 AM
icepilot's Avatar
Default Calibrating ECU temperature
Hi guys!
I have just installed a GBooster 160 in my Liebetrau SU-27, but when I turn the ECU on,
I get a temperature reading of approx 60 degrees Centigrade - is there any way to calibrate
the ambient temperature on an ECU?
Thanks!
Tor
Old 03-06-2009 | 04:43 AM
My Feedback: (10)
Default RE: Calibrating ECU temperature
ORIGINAL: icepilot
Hi guys!
Thanks!
Tor
ok thats it i am coming to iceland next week..
with those temps all goes well....
on the other hand i measured once a booster up its ass , and the shown temp was 680 and the measured temp was 840..
but then my calibrated meter could be wrong..
Old 03-06-2009 | 06:28 AM
My Feedback: (57)
Tor, it's parameter #47 under the Autostart Menu:
To enter the 4:AUTOSTART menu, first press the SET key and then use the Up/Down keys to switch between the available parameters.... 47: EGT/AMBIENT
Use this parameter to adapt the temperature sensor (EGT zero point) to the current ambient temperature
Standard value: e.g. 21 °C (70 °F)
After a re-installation, this setting should be checked and corrected if necessary!
To change a setting, first press the SET key and then use the Up/Down keys to switch between the available values. A ? indicates the value to be set. To finish the setting and store the new value, press the SET key again.
Old 03-06-2009 | 06:54 AM
schroedm's Avatar
Yep, what he said
Just done this on my new install.
Old 03-06-2009 | 09:26 AM
icepilot's Avatar
Thanks, guys - I actually sat down and read the manual today!!!!!! and found it just like George said!
I have adjusted it and ran the turbine today, just perfect! I wish Norway was warmer, but 63 degrees.....
Thanks!
Tor
Old 03-06-2009 | 11:31 AM
I thought maybe you were in Death Valley at 150F. Hey, it could happen!
Old 03-06-2009 | 12:55 PM
Selleri's Avatar
ORIGINAL: digitech
If you do come here next week let me know so I can have you bring some stuff for me
Old 03-07-2009 | 04:24 PM
ela
..and if you replace the original battery with another type and makes the change in the ecu accordingly, you will have to recalibrate again.
Good to hear you project is moving on.
Eivind
