RE: I need a homlite 25 ring
The Frank Bowman ring will be much better than a stock replacement. For the Homelite 25cc, you can also send him the piston and he will install a pin, and supply a ring configured for use with a pinned piston. Then you can grind out the bridge in the exhaust port for a further power increase. It is worth the trouble....
AV8TOR
