RCU Forums - View Single Post - High Speed Flutter -Help!
Old 03-07-2009 | 06:14 PM
CGRetired's Avatar
CGRetired
Default RE: High Speed Flutter -Help!
Well, the first thing that comes to mind is to slow it down. Perhaps that plane is not designed for fast flight. If you don't slow it down, it will fix itself.
If you built it, and hinged it, check to see if there is a gap between the surfaces. If so, close the gap using covering or tape.
