RCU Forums - View Single Post - Ugly Stick Build
Thread
Ugly Stick Build
03-08-2009 | 12:31 AM
50
Nergall
Jun 2008
428
, GA
RE: Ugly Stick Build
I went on to work on the wing pin. I had to re-drill the hole because it had filled with epoxy when I glued the plywood piece to F2.
It ended up not quite where it needed to be, unfortunately.
In the first picture, I'm refilling the hole with epoxy and shims to keep the pin snug. In the second picture, I'm gluing the pin into the wing.
I'll let this dry overnight, and then I can re-measure everything and drill the rear wing bolt holes.
Reply
Like
Nergall
View Public Profile
Send a private message to Nergall
Find More Posts by Nergall
View iTrader Profile
