Got a small snag-first edf
Hi guys:
A good flying buddy dropped off a HET F18 last night he picked up at a swap sale. So, got out the fan assembly, a 6904 system and ran into a snag right away. After fitting things as per instructions, I could not tighten the fan onto the adapter shaft. The screw into the adapter shaft just keeps turning the inrunner motor over whthout clamping down as it should. Am considering applying a little red locktite to the motor shaft and then let it set up prior to trying to tighten. There is a motor bearing in the bell end that could also get stuck. Have not found anything in this forum dealing with the problem. Any tricks or suggestions?? Thanks
