RCU Forums - View Single Post - rudder
Thread: rudder
Old 06-12-2003 | 06:19 AM
Rawlie
Default rudder
What dual rate and exponential settings are you using on rudder?
Also what is your rudder ATV set at?
Are you sure its not a mechanical problem - does the rudder move freely if you disconnect it from the servo and just push it by hand? Also, I'm assuming that there is no binding on the rudder pushrod?
