RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
rudder
Old 06-12-2003 | 02:44 AM
Default rudder
hello i was flying my raptor today and when i turn i have to give it a lot of rudder do i need to change somthing on my Tx, RD6000 sport.
thanks
Old 06-12-2003 | 06:19 AM
Default rudder
What dual rate and exponential settings are you using on rudder?
Also what is your rudder ATV set at?
Are you sure its not a mechanical problem - does the rudder move freely if you disconnect it from the servo and just push it by hand? Also, I'm assuming that there is no binding on the rudder pushrod?
Old 06-12-2003 | 12:03 PM
`3D
Default rudder
to slow of a head speed??
Old 06-13-2003 | 02:20 AM
Default rudder
hello thanks for getsing back.
my dual rate is set at 100% and my EPA is 55%
and my gyro is 68 % .
the rudder dose move freely if you disconnect it from the servo and just push it by hand and there is no binding on the rudder pushrod.
thanks
Old 06-13-2003 | 08:26 AM
Default rudder
Firedup
If you main rotor headspeed is too slow that can cause problems because the tail rotor will not spin fast enough (like 3D said). Is your headspeed around 1600 rpm when you hover? Do you use about 5 - 6 degrees of pitch to hover? If you are using more pitch, it probably means your headspeed is a little low.
Hope this helps
Old 06-22-2003 | 01:29 PM
Default rudder
if your rotor speed is ok then try increasing the epa to 70%,i have the same radio and when i lower the rudder epa to about 50% i find that the rudder is not sensative enough
