Thank you for the answer Brett. Right now my setup with this plane has no mixes at all. The plane does knife edge ok at the moment but not perfect, as it has slightly pull to the canopy just a little bit at both side where the down line has a little bit of pull into the canopy. I believe i setup the down trust right as you said till the up line has no pull where my CG sets at ~190mm and my stab incident right now sets at + 0.4.
This stab incident is my really first setup as i believed the wing was 0 so I set the stab the same angle as the wing. I will try move my CG 170mm as you said and think i will have to adjust my stab to 0 to begin with. I will try it in couple of days and i will let you know if this works.
Thanks again for your time, I would ask hof more help later hope you wouldnt mind
Patrick S
