ORIGINAL: brett65
Just stick the bind plug into the batt/bind port with the battery plugged in somewhere else. If you lost your plug, just use a piece of wire or make a new one by splicing the outer wires together on a spare servo extension or the wire from an old bad servo.
For some reason I have about 4 bind plugs and only 2 RX-s Thinking about getting the Cheaper RX to use on some of my planes. The AR7000 you need to be a drug dealer to afford many of them.
Only kiddingthat was my profession before I retired. A drug counselor. (not a dealer)
