 Binding a DX-7 without a 3 wire switch >
Old 03-09-2009 | 12:08 PM
goirish's Avatar
Default Binding a DX-7 without a 3 wire switch
I know that I have seen somewhere how you can bind the DX-7 without using a 3 wire switch. I Searched but guess I don't know where to look. Most of my planes have the switch containing the charge jack all-in-one. So I only have two wires coming out of the back of the switch. How do I bind my new AR7000 without having to buy a spektrum switch.
Old 03-09-2009 | 12:14 PM
Default RE: Binding a DX-7 without a 3 wire switch
Try putting the bind plug in the aux1 or aux2 channel I can't remember which one, or i think you can also put it in the batt port, and just put the batt through a spare channel.
Old 03-09-2009 | 12:20 PM
Move the batt to any other port and put the bind plug into the batt port on the RX.
You dont need the 3 wire swith.
Pop
Old 03-09-2009 | 12:27 PM
brett65's Avatar
My Feedback: (18)
Just stick the bind plug into the batt/bind port with the battery plugged in somewhere else. If you lost your plug, just use a piece of wire or make a new one by splicing the outer wires together on a spare servo extension or the wire from an old bad servo.
Old 03-09-2009 | 12:30 PM
goirish's Avatar
ORIGINAL: jantrit
Pop
Thanks guys, what would a dummy like me do without RCU
Old 03-09-2009 | 12:33 PM
goirish's Avatar
ORIGINAL: brett65
For some reason I have about 4 bind plugs and only 2 RX-s Thinking about getting the Cheaper RX to use on some of my planes. The AR7000 you need to be a drug dealer to afford many of them. Only kiddingthat was my profession before I retired. A drug counselor. (not a dealer)
Old 03-09-2009 | 12:41 PM
brett65's Avatar
My Feedback: (18)
That's good, I interned in the state drug lab, OSBI, to finish my school. We saw a bust of a few dealers in there. Got to help test a 30lb. brick of marihuana.
Old 03-09-2009 | 12:50 PM
I tested 30 lb bricks of dope when I was younger.
Old 03-09-2009 | 01:02 PM
brett65's Avatar
My Feedback: (18)
tested=smoked?
Old 03-09-2009 | 01:04 PM
Don't ask , Don't tell.
Old 03-09-2009 | 01:11 PM
BarracudaHockey's Avatar
ORIGINAL: jantrit
It only works in the batt/bind port.
Old 03-09-2009 | 02:39 PM
It's ok as long as you didn't inhale!
pop
Old 03-10-2009 | 11:14 AM
jib
ORIGINAL: goirish
I've been happy with the singe receiver - AR500. No performance issues at all and almost half the price of an AR7000. It's only a 5 channel, but that's all I need on most of my planes.
Jack
