RCU Forums - View Single Post - Axe CP brushles upgrade trouble. Warning, kind of long
Old 03-09-2009 | 03:53 PM
Shadow99
Default RE: Axe CP brushles upgrade trouble. Warning, kind of long
Toss the electric tail motor and get yourself the Belt-Drive kit, or the new shaft-driven (torque-tube kit). There is NO comparision between the WEAK & WIMPY [:'(] (ETM), and a DRIVEN tail rotor with true positive & negitive pitch !
Did the conversion over 2yrs ago on my AXE CP v1, and never looked at an Electric-tail again!
Also, your BL main motor is way more powerful than you really need, your headspeed must be somewhere around 2800 RPM's!
To figure out the headspeed in RPM's= (Motor Kv * Nominal battery voltage * 90% effiency * Motor Pinion tooth count)/Main gear count. EXAMPLE: 3700*11.1*.9*14/186= 2782 rpm's
Shadow
ID:	1153954   Click image for larger version
ID:	1153955   Click image for larger version
