RCU Forums - View Single Post - old engine parts
Old 03-09-2009 | 08:29 PM
cutaway
Default RE: old engine parts
If you just want to get it running, a C/L needle valve assembly for a Super Tigre G.34 should fit OK. You may need to pack it out a bit with some washers to get the hole centered on the intake since the old Greenhead's venturi is a bit smaller in diameter than the G.34.
