RE: Engine Hard to Start
I reset the motor back to factory settings. Both the HSN and LSN. I found that the gap for the carb was a little too closed. So I opened it up a bit. I took it out this morning and she fired right up hahaha But I didn't get a chance to run it around, it started raining. But I'm getting ready to go and try it again and make sure everything is in order. So something to look at is the carb opening. Making sure you have that 1mm gap.
