Originally posted by slodsm
WS7 is a great motor, if you don't want to drop the cash, pick up an S7, its around 50 cheaper and there is no difference in power, just in the crankshaft coating. Also, you will want to replace yor spur gear that came on the Sports and go with a kit spur, also check the shimming of your diffs cause the RB motors make a LOT or power compared to a sport engine, if it is all not together nicely, it will strip them out.
Could you elaborate on the shimming part? Not to sure what you mean. Does anyone know where you can by RB engines on the web?
NewHyper7: your probably right, I should sell it all and put the money in my IRA.....but what fun would that be. You need to be changing your screen name to kanai II
