RE: Problem tuning my 55ax
Thank you all for your help, it seems to be running better and better. No bubbles, and rpm does increase slightly when I pinch the line at full throttle after about a minute, temp is perfect and power is steady. I have about a gallon maybe less of fuel through the 55ax. Thank you for all your help, it was very helpful. It seemed to response perfect to 3 turns out exactly. Im running a 12x4 prop and it turns it with the jett muffler with ease. Again thank you fellas.
