RCU Forums - View Single Post - multiplex easy glider
Old 03-12-2009 | 05:51 PM
snobelt
Default multiplex easy glider
Have any of you put a 2.4 ghz radio in the Easy Glider? All info I find on the plane refers to the 72 Mhz radio with the long antenna routed through the fuselage. Is there enough room to place the two shorter antennas of the 2.4 Ghz receiver within the available space? The obvious problem is the required 90 degree orientation of the 2.4 antennas. I have asked HiTec/Multiplex and they say it should be possible but they have not tried it. Your thoughts?
