ORIGINAL: TGreg
ORIGINAL: MMT GUNS
I think adam313 is into bashing his truck what makes me think he dosent care much about Racing fuel as far as bashing goes. Blue Thunder have Racing fuel as well either he could go racing 20% or bashing 30% blue thunder got him cover and yes it dies your engine blue FOR ENGINE PROTECTION read.
I never heard a person with commonsense dissing Blue Thunder at all (ignorance) I wouldn't say the same thing about Biron or the XTM fuel I heard they are good as well.
[link=http://dynamiterc.com/Products/Default.aspx?ProdID=DYN2370]Blue Thunder Racing Fuel[/link]
relax man!! haha no ones dissing your blue thunder. its good. its not crappy fuel. but 1. its not the best and 2. blue dye does not protect your engine. Honestly he should just use whatever fuel his hobby shop carries to make it easy on him.
Im on your side man, your from Green Bay, ive been a packer fan since i was five.
On a side note, this so called "RTR Fuel" or "Sport fuel" or whatever the companies are calling it these days are worst for your engine than racing fuel. theres a reason why its cheaper, its because it uses more oil than nitro, which to a person just getting into the hobby thinks is great but its really not. They use more oil in them to cut cost, not protect your engine, it actually cause your engine to run hotter with more oil.
Idk if that makes sense. But in other words, racing fuel has the perfect blend of nitro to oil, while rtr or sport fuel has a abundance (or too much) oil which is bad for you engine. Its almost like with two stroke lawn mower how you have to mix your own fuel, its like putting double the oil in that your suppose to, not good for your engine, gums it up.
Which is why i recommend no less than 20% nitro fuel, i have ran and always will run 30% regardless of what brand it is.
Cheers!
