RCU Forums - View Single Post - Pull-Pull
Thread: Pull-Pull
Old 03-13-2009 | 09:28 AM
Rodney
Default RE: Pull-Pull
I have never had a problem doing the crimps. Go to your sporting goods store and pick up some ferrules (they come in different sizes so pick one that will fit your lines) like those used in fishing line. You can crimp them using dikes (diagnal cutting pliers) a kind of pliers that electricians use to cut wire. Just use enough pressure to nicely crimp the ferrules tight. To much pressure and you will cut them in two.
