RE: Anyone running Blade 400 with Align 430x motor
Did you factor in inefficiencies of the motor and friction? You probably get around 85% max efficiency. Then with old batteries the headspeed will also be slower. You could also lower the throttle curve to get the headspeed you need with a 10T or 11T pinion.
Nick
