RE: Anyone running Blade 400 with Align 430x motor
I'm running the 430XL motor in my blade. i used a 11 tooth pinion. I did this because there is not enought metal in the smaller count pinion due to the larger 3mm shaft. I think that your target of 2200 rmp is way to low. You need 2800 to 3000 and the heki will be more stable.
