RCU Forums - View Single Post - How do I remove the ailerons
Old 03-14-2009 | 07:00 AM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: How do I remove the ailerons
You may cut them if they are CA hinges, however if they are nylon hinges that have been installed with epoxy or a good hinge glue, your best choice may be to leave them alone as they will ruin something if you try to pull them out. As for removing your covering, just tear off as much as possible. You may need to do some sanding to get the edges cleaned up, but it should pull off. Good Luck, Dave
