ORIGINAL: mustangflyboy1
Does your guys' motor have a tiny bit of play when rocking the prop back and forth (on the plane of rotation) ? Mine does, not sure if this is normal. Haven't ran it yet.
Can someone who has the timing set as recommended please measure (in Millimeters ) the distance between the middle of the magnet and the middle of the sensor when at TDC ?
About 1/32 to 1/16 play at the tip of the prop is normal.
You can leave the timing at its default.
